vdo oil temp sender
Posted: Fri Jan 07, 2011 8:31 am
by Gilb666
Hi all
Just picked up a set of VDO gauges, and seperatly a set of senders
What do i need to connect to the top of the temp sender? i've not seen a connection like this before
a pic of something similar -
http://shop1.actinicexpress.co.uk/shops ... arge-1.JPG
anyone know what i need, or better yet where i can get it?
Marcus
Re: vdo oil temp sender
Posted: Fri Jan 07, 2011 10:02 am
by PeteGLi
Standard female blade connector.
Have a look at your current water and oil temperature senders - the wires connecting to them will show what you need.
Posted: Fri Jan 07, 2011 10:58 am
by Gilb666
Its not the same as the water temp sender (presuming i've got the right one, right hand side of the cylinder head?) as that has a standard spade connector
the pressure sender also has the same normal spade connectors
The one on the oil temp sender is more like a half sized drawing pin / mushroom shaped thingy
Posted: Fri Jan 07, 2011 12:02 pm
by Birdy
A spade connector will still be fine, slide it over the pin and it'll work
Posted: Fri Jan 07, 2011 12:37 pm
by Jay4424
Birdy wrote:A spade connector will still be fine, slide it over the pin and it'll work
more than fine, it is what its suppost to be, as previouse posts.
..solder it if your really that bothered!
Posted: Fri Jan 07, 2011 1:23 pm
by Gilb666
was trying to figure out how to make a spade conenctor fit it, i've only just through it will fit over the other way lol
Cheers guys!
