Really cheap immobiliser trick (unless i'm missing something
Posted: Tue May 19, 2009 7:05 pm
by Niall
Idea came to me sitting on the bus this morning (Car off road).
Ignotion system runs about 2 or 3 cables into the engine bay yes?
Would it be possible to run them back into the dash and put a little on / off switch in before running it back to the engine bay.
You could locate the switch wherever you want (hidden preferably). This way you could immobolise your car so that the ingnition would only work when the switch was activated.
The reason I would run it back from the engine bay is to make it more difficult to hotwire. Seeing as when most cars are hot wired the keyhole gets yanked off and wired from there, by moving the switch further down prevents them going past it.
Is this possible?
Have I missed something crucial or does everyone do this anyway?
Your thoughts
Niall
Re: Really cheap immobiliser trick (unless i'm missing something
Posted: Tue May 19, 2009 7:24 pm
by filmidget
People have been doing similar for years...
Another method that only requires running one wire, is to earth the coil through a hidden switch - will turn over but not start.
Posted: Tue May 19, 2009 7:58 pm
by Jetfire
Or just take out the fuel pump relay for the injection cars.
Posted: Tue May 19, 2009 11:30 pm
by Risocco
filmidget wrote:Another method that only requires running one wire, is to earth the coil through a hidden switch - will turn over but not start.
Sorry, I'm useless with electrics (ask Mr Baker) could you please explaine to me how to do this in plain English?
If I sounds thick its cuz I r.
Alex
Posted: Wed May 20, 2009 9:05 pm
by Joe87
Jetfire wrote:Or just take out the fuel pump relay for the injection cars.
Yeah that's what I do - you'd have to take the fuse box apart and figure out which wires (out of about 6) go together to get the car started without it...
Posted: Fri May 22, 2009 9:33 am
by kariba
As an auto electrician, this is the best of the cheap immobilisers
Another one is disconnecting the battery neg terminal. They'll eventually figure it out, but its all about buying time...
Posted: Tue May 26, 2009 12:56 am
by Joe87
kariba wrote:Jetfire wrote:Or just take out the fuel pump relay for the injection cars.
Chances of a car thief happening to have the correct relay are fairly slim though... :p
Posted: Tue Jun 02, 2009 4:51 pm
by Junglist
What's best on non-injection? Don't want to disconnect battery as I'll lose all the settings in my stereo and clock.
Posted: Tue Jun 02, 2009 7:14 pm
by james butler
yeah m8 thats wot ive dun on mine make a break in the earth wire on the negative side of the coil and bring it up to the dash somewhere only u know. bobs ur uncle
