Removing oil cooler
Whitescala89
Removing oil cooler
Post by Whitescala89 »
I have a serious oil leak coming from the oil cooler. I have narrowed it down to the seal between the cooler and the housing. Any idea how to remove the cooler? It is a later water cooled type. Thanks
scirsteve
Re: Removing oil cooler
Post by scirsteve »
You'll have to drain the coolant, undo the two coolant hoses to the cooler.
Undo the oil filter, once you've got the filter off you can undo the big nut on the filter pipe that the filter screws onto.
I think it might be about 24-27mm diam, then you can remove the oil cooler.
mk2 gtx
DannyH
Post by DannyH »
not suggesting you're wrong, but that's what i thought and
http://sciroccoregisterforum.co.uk/carf ... f=9&t=7927
so it might be worth checking the switch it was cheap on ebay
Danny
