7.5 inch rims
Posted: Tue Nov 23, 2010 9:12 pm
by thebrief_1979
Hi guys, any advice appreciated on this topic
i have a standard mk2 gt2 scirocco 1993 and its on 15 inch bbs ra's
possibly looking to put different wheels on it - thinking of 7.5 wide rims - if i put 195 wide tyres on it will they go under the arches without rolling them
cheers
Re: 7.5 inch rims
Posted: Wed Nov 24, 2010 9:49 pm
by GTXTRA
you'll need 45 series rubber - ronal ls a good fit at that 7.5 x 15 size.
Re: 7.5 inch rims
Posted: Fri Jun 17, 2011 11:43 am
by thebrief_1979
will i get away with 185/50/15 on a set of Ronal LS's - if not what size (195/45/15?) would you reccomend without rolling the arches
failing that how much are my 15" bbs RA's in very good condition with part worn (5mm) firestones 185/50/15 worth?
tring to work out the best value solution
thanks
Re: 7.5 inch rims
Posted: Fri Jun 17, 2011 7:49 pm
by benlg81
im running 15x7.5 et 23
1955015
lowered 40mm and no issues at all even loaded up
Re: 7.5 inch rims
Posted: Fri Jun 17, 2011 7:56 pm
by Col
i've used 16x7.5j et25 rims before. 205, not sure on profile. they where too wide offset. on standard suspension, any load inn the back caused rubbing. 15's with lower profile / thinner tyres could be a different kettle of fish though.
ive still got those wheels, probably going to sell them on after a refurb.
