can you is it possible
earl thebay
Post by earl thebay »
i have a small problem with my engine sump scraping the ground every now and then.
is it possible to raise the engine up 1" without to much work eg useing other types of mounts ?
Re: can you is it possible
Be much easier to raise the suspension. Raise the mounts up and I'd reckon you're in danger of the engine block touching the bonnet
or investigate either shallower sump or 'dry' sump so it doesn't stick down as far
