removing servo... any help??
Posted: Thu Oct 07, 2010 11:04 pm
i am currently fitting an agu 1.8t lump into my mk2 scirocco and would like to do away with all the servo. linkage setup to fit up some room for intercooler piping etc
i have read that this is possible to do by buying/making a pedal box which sits behind the dash with a brake bias bar and two master cyclinders, one for front, one for back, what im wanting to know is what size cylinders should i be looking to use? also i take it you just t-piece of the cylinder and then run one line to each side, also how do the remote resivours work?? do you also just plumb these in one to each cylinder and have to be located at the highest point of the system? ive not had a chance to have a proper look at the brake system tbh so apoligise if these questions were stupid
also i have seen on a couple of mk1's that the master cylinder(no servo) can be mounted in the engine bay on the drivers side, from what i have read this is a 17mm master cylinder of the earlier mk1???? is this right, i imagine this setup wont have enough braking force that is ideal for a 1.8t though??
any info on brake setups/pedal boxes etc etc would be extremely appriecated and save me loads of time trawling the net for answers
thanks liam
thanks liam
