MFA - Ambient -40
Posted: Tue Oct 05, 2010 11:23 am
by iroberts696
Hi,
Anyone know where the Ambient Temp Sensor for the MFA is located and which wire should be connected as mine is now reading -40 hence suspect sensor is faulty/damaged or not connected.
MK2 Inj Scala.
IanR
Re: MFA - Ambient -40
Posted: Tue Oct 05, 2010 1:08 pm
by eamon1.3
Think its on the front right, just behind the bumper, or inside the bumper somewhere
Posted: Tue Oct 05, 2010 8:57 pm
by ianaudia4
It is on the drivers side behind the bumper.
Posted: Tue Oct 05, 2010 11:00 pm
by Funky Diver
iroberts696 wrote:mine is now reading -40 hence suspect sensor is faulty/damaged or not connected.
Ian, you live in Glasgow, it is ALWAYS that cold up there, thought you chaps were used to it by now
You know it's that cold around here when a lass puts a cardi on to go out... which is never!
Posted: Fri Oct 08, 2010 10:22 am
by iroberts696
Thanks, sometimes nice to know how cold :)
Posted: Wed Oct 13, 2010 4:06 pm
by iroberts696
Located sensor as per above, the sensor was missing on my new vehicle, replaced with previously working sensor on former vehicle. However MFA still reading -40, despite hard reset via fuse removal.
Have tried sensor both ways round , same same, presume sensor is a thermistor anyone know ? or what voltage should show if meter plugged in place of sensor to check its connected.
IanR
Posted: Wed Oct 13, 2010 7:23 pm
by bensspares
try the posative feed wire. there is an open circuit somewhere.the guage reads from-40 to +40.try disconnecting and reconnecting the battery,this has worked for me in the past.
