After having my rocco recently stolen whilst I was getting the repairs done to the steering column my mechanic pointed out that I when you turn high beam on, the drivers side light goes out and I have no horn. The fuse is ok and the horn is not faulty as its been tested seperately. Any ideas? I'm a compete novice when it comes to techie stuff.
Cheers in advance
Problem with horn and High Beam
Re: Problem with horn and High Beam
Try the earth on the back of the head (brown wire) had a simular prob last year... Failing that try the earth on the steering rack
I vaguely remember that someone on here had similar symptoms a while back, and it turned out to be a faulty ignition switch. Could have been damaged in the breakin?
