Right then, time for an update!
As you may/may not be aware, Project Pink passed its MOT on Thursday and made its maiden voyage home yesterday (taxed as well!) without a hitch. Went straight through with NO advisories
Need to upload some photographs but thought I'd list all the work done since my last post:
Engine was stripped, head removed and stripped and sat in an acid bath for a couple of days. Head then rebuilt was new valve stem oil seals, valves lapped back in etc etc.
Block was externally stripped, wire brushed and painted. All new gaskets fitted and components refitted.
Engine rebuilt with new hoses, water pump and thermostat, fuel pump, cambelt and tensioner, rubber rocker gasket mod, o/s engine mount and clutch. Gearbox was cleaned, oil changed and reunited with the engine.
Whilst engine was out, ALL metal brake pipes and flexi's were replaced, having already replaced the metal fuel pipes. Anti-roll bar rubbers and clamps were replaced. Engine bay was cleaned.
Engine then refitted and complete brand new mild steel exhaust system inc rubbers purchased and fitted. I know it's not a sports system but its got a lovely rasp to it!
New battery, air filter bobbin, discs and pads fitted to the front along with new rear wheel bearings and wiper blades and, yesterday, 4 brand new Uniroyal tyres (tyre supplier can't remember when they last sold 175/70 TR13!
I'm sure I've forgot something but I can update when I sort the pictures.
Still to do:
Weber carb needs an overhaul (got the intermittent sticking needle valve syndrome)
Double check everything is tight!
Vac pipe ends need replacing before Ian sees it
Ignition timing needs tweaking
New barrel in o/s door lock
Reclean the engine bay (good layer of dust on it again)
Fit new bumpers I have for it
A bit of interior work (cleaning and steering cowel)
Remove oily finger prints and give it a light polish (nothing too heavy as respray planned for later this year) and some temp touching in
and finally - enjoy it!
Hopefully first show outing will be the club stand at Stanford Hall
