Hints, tips and guides for repair and modification - the FAQ section on the main website is worth checking first for information relating to common faults and technical help. Useful posts and guides will be added to the FAQ
http://www.sciroccoregister.co.uk/scirocco-faq
robwizard
Posts: 7 Joined: Wed Aug 25, 2010 11:16 pm
Post
by robwizard » Sat Sep 11, 2010 1:14 am
i was wondering (i have read and perhaps misinterpreted..) that mk2 hubs and mk1 golf hubs are the same as mk1 rocco hubs?
anyone know for sure?
cheers
robwizard
Post
by robwizard » Sat Sep 11, 2010 8:37 pm
Ok further reading leads me to believe they are the same.. or certainly where the strut bolts on is the same :/
also i have read that on very early roccos the balljoint is much smaller but this does not apply to me..
can anyone confirm this so i dont go wastin my hard earned pennies?
cheers
PeteGLi
Posts: 920 Joined: Thu Mar 05, 2009 8:37 pm
Post
by PeteGLi » Sun Sep 12, 2010 10:23 am
robwizard wrote: Ok further reading leads me to believe they are the same.. or certainly where the strut bolts on is the same :/
cheers
Early balljoint size was 15mm. Later size is 17mm. You can fit the later size balljoints to an early hub, but you have to ream out the hole in the hub to fit.
What are you trying to put on where?
robwizard
Post
by robwizard » Sun Sep 12, 2010 12:31 pm
i just need new hubs and seen as mk1 hubs seem to be hard to come by and there are quite a few people breaking mk2s i was wondering if they would fit?
cheers
Posts: 3800 Joined: Wed Apr 01, 2009 4:35 pm
Post
by ianaudia4 » Sun Sep 12, 2010 1:03 pm
Front wheel hubs from Big Boys Toys cost £13.41 each, these are MK1 Golf ones.
robwizard
Post
by robwizard » Mon Sep 13, 2010 10:54 am
yeah i already spoke to them and i need both the hub and the strut assembly part.. so does anyone know if mk2 will fit?
cheers
The Autoad
Posts: 732 Joined: Sat Feb 28, 2009 5:57 pm
Post
by The Autoad » Mon Sep 13, 2010 6:59 pm
Mk 2 Scirocco or Mk1 Golf hubs will fit just fine on your mk1 with 17mm ball joints.
PeteGLi
Post
by PeteGLi » Mon Sep 13, 2010 7:17 pm
ianaudia4 wrote: Front wheel hubs from Big Boys Toys cost £13.41 each, these are MK1 Golf ones.
That is just the "hub" - the part the brake disc attaches to.
robwizard wrote: yeah i already spoke to them and i need both the hub and the strut assembly part.. so does anyone know if mk2 will fit?
cheers
The other part is the 'wheel bearing housing' and costs - with bearings and hubs - £120 plus £16.50 shipping from Crazy Quiffs - golfmk1.co.uk
http://www.golfmk1.co.uk/Items.php?cat= ... SUSPENSION
Calvert
Posts: 48 Joined: Sun Aug 22, 2010 11:47 pm
Post
by Calvert » Tue Sep 14, 2010 10:04 pm
As far as im aware the hubs are the same.
But, the hub carrier is different from a mk1 to a mk2. The suspension bolt holes are in different locations.
stu.gtx
Posts: 271 Joined: Mon Apr 06, 2009 1:24 pm
Post
by stu.gtx » Tue Sep 14, 2010 11:50 pm
I fitted a Mk1 golf hub assembly to my Mk2 Rocco if that's any help.
PeteGLi
Post
by PeteGLi » Wed Sep 15, 2010 9:42 am
Calvert wrote: As far as im aware the hubs are the same.
A Mk2 Golf hub carrier is different.
Mk1 Golf, Mk1 and Mk2 Scirocco carriers are the same.
