mk2 petrol tank
1492.aircooledfan
mk2 petrol tank
Post by 1492.aircooledfan »
just bought a scirocco, tank is 3/4 full of bad fuel, been in for years, does the tank have a drain plug? or do i have to swollow half of it trying to syphon it out, any suggestions please. :newbie:
Re: mk2 petrol tank
There is a rubber connecting pipe from the fuel filler neck to the tank, disconnect that and jack the front up to allow it to drain. Might be worthwhile checking the filler neck at the same time as they are notorious for rotting through.
Good luck mate.
Re: mk2 petrol tank
open the top of the tank (under the rear seat) and to stop yourself getting a gobful, buy one of those jiggle syphon thingies
1492.aircooledfan
Re: mk2 petrol tank
ianaudia4 wrote:There is a rubber connecting pipe from the fuel filler neck to the tank, disconnect that and jack the front up to allow it to drain. Might be worthwhile checking the filler neck at the same time as they are notorious for rotting through.
Good luck mate.
many thanks from a frustrated air cooled fan
1492.aircooledfan
Re: mk2 petrol tank
Nate wrote:open the top of the tank (under the rear seat) and to stop yourself getting a gobful, buy one of those jiggle syphon thingies
looks like a trip to halfords for a thingie, many thanks Tom
