COOLANT LEAK
tinkerbel
COOLANT LEAK
Post by tinkerbel »
iTS COMING FROM WHATS CALLED THE CONECTION, WERE THE HOSES GO TO,IN HAYNES BOOK IT SHOWS AN O RING ANYBODY KNOW THE PART NUMBER. I DONT THINK ITS A BIG JOB, YOU WOULD HAVE THOUGHT THEY WOULD HAVE HAD A GASKET ON IT. :read:
Re: COOLANT LEAK
rubber seals on the cooling system are becoming increasingly common. just go to your local vw main agent. they may well have it in stock and it will be cheap.
