Random stalling - not sure why...
Posted: Fri Jul 09, 2010 7:27 pm
OK. I'm not sure where this problem lies - so I'll just tell you the running order and we'll see...
I was driving back home a few days ago - fuel needle was at the top of the red. I'm not used to the car, so I assumed that was fine. Suddenly, the car started to stammer. 5 secs later - dead. Managed to freewheel to a layby and call the missus. Assuming a sticky float in the tank (ie. I'd run out) - I stuck 5l in and away we went. I must say at this point that once it conked out I didnt try more than once to restart the car until I'd got more juice. It'd cooled down considerably by the time I filled it with the can.
So - last night - took it for a quick pre MOT run. 1/2 a mile up the road... stammered and conked out. It literally dies in 5 secs. Pulled over. Wouldnt fire (cranks OK). 2 mins later - fired up fine and home we went.
So - assuming that 5l aint enough - I stuck £20 in.
This morning was MOT day (nerves killin me!). 4 miles from home.... stammer and conk. Tried and tried to start it - wouldnt fire. Sat 5 mins... fired fine. Made it 6 miles.. same again.
Got to the MOT centre and with heart in throat went through... (NI - has a govt run test centre - you have 1 shot at it on the rollers for brake bias tests etc etc). The car passed with flying colours I'm glad to say.
Made it 5 miles without issue to work.
Coming home this afternoon - same conking issue - 3 times
So - fault finding time: 1 thing I'm wondering... did I run out of fuel at all on Tuesday? I'm doubting that now. Its behaving the very same with £20 in the tank. However, if it DID run out, maybe theres crud in the lines. But that wouldnt explain it conking - and starting fine 3 mins later. The crud wouldnt just disappear.
Someone suggested it could be the coil on the way out. Its in a really crap place IMO - with all that heat round it. I looked at the fuel line to the carb tonight as it ticked over in the drive. Theres a wee inline Fram filter near the carb - and theres no crud in there. However, at tick over - theres LOTS of air bubbles travelling in the line. Is that normal?
I'm stumped - and quite pi**ed off. This is the last hurdle to getting this wee Cat D back to top form.
Any ideas?
Any ideas?
