Dash Clocks
Posted: Tue Jun 22, 2010 9:44 pm
by NiceOne
Hi i have recently aquired a couple of sets of dash clocks both with about 120k on them, one of them i have never seen before so i dont know what model its off, it has the usual 2 plugs on the bottom but one of them is much smaller than the other, it only goes up to 120mph and has a vacuum mpg guage at the top where the engine temp normally is, the temp guage has been relocated in the rev counter. Does anyone know what this is worth, and is it worth me selling it
Re: Dash Clocks
Posted: Tue Jun 22, 2010 9:53 pm
by bluestreak56
Stick some pics up and Ill try and help you figure out which are which..
Sounds like the smaller one is from an earlier Mk1 Golf Gti (presuming theyre the same shape)
Re: Dash Clocks
Posted: Tue Jun 22, 2010 11:08 pm
by ianaudia4
Earlier clocks had the gear change indicator on the top, if it has an MFA it will be from a Storm, early GTX or GTi (1.8). The non injection GL also had the gear change indicator as well but no MFA. One thing you can look at is what colour the main beam warning light is, on early Scirocco's they were orange, my 84 Storm has a blue one.
Re: Dash Clocks
Posted: Thu Jun 24, 2010 7:12 pm
by NiceOne
It doesnt have an MFA but it does have a mechanical mpg clock at the top which runs off a vacuum hose im not sure where from though, i will try and get some pics up tomorrow
Re: Dash Clocks
Posted: Thu Jun 24, 2010 10:31 pm
by ianaudia4
Either from a 1.6 GTi or a GL mate.
Re: Dash Clocks
Posted: Fri Jun 25, 2010 8:42 am
by NiceOne
cheers for that, is it worth me selling and whats it worth
Re: Dash Clocks
Posted: Sun Jul 04, 2010 12:11 pm
by Rob88
ianaudia4 wrote:Earlier clocks had the gear change indicator on the top, if it has an MFA it will be from a Storm, early GTX or GTi (1.8). The non injection GL also had the gear change indicator as well but no MFA. One thing you can look at is what colour the main beam warning light is, on early Scirocco's they were orange, my 84 Storm has a blue one.
Not always,I have an early 82 mk2 GTI 1.6i with the original clocks and it has an MFA and an orange main beam warning light.
Re: Dash Clocks
Posted: Sun Jul 04, 2010 4:03 pm
by ianaudia4
1.6i's were not fitted with MFA's as standard, have your clocks been changed, sounds like it?
Re: Dash Clocks
Posted: Sun Jul 04, 2010 4:24 pm
by Rob88
No,the clocks are original.
Re: Dash Clocks
Posted: Sun Jul 04, 2010 5:53 pm
by ianaudia4
What year is your GTI then? I am intriged, I have never seen an MFA on a 1.6i VW of any shape or form, please take a picture and post on here.
Re: Dash Clocks
Posted: Sun Jul 04, 2010 6:55 pm
by Rob88
Just been reading up on it and had another look and you are quite right and I am a complete numpty
Because it has a tube that connects to the rear I thought that was part of an MFA,shows how much I know about scirocco's.
I'll get me coat
