Single wiper arm on earley mk2
Posted: Tue Jun 08, 2010 5:21 pm
by #Riggs#
Single wiper arm on my Scirocco mk2 1983,not sure if anyone can spread some light on this little problem I have.I wont to change the arm on my single wiper arm so that it sits on the drivers side anybody know if thire is a conversion for this?
Re: Single wiper arm on earley mk2
Posted: Tue Jun 08, 2010 6:47 pm
by PeteGLi
If I understand you right - you want the blade to rest on the driver's side rather than the passenger side when it comes to rest.
Unscrew the holding nut, remove arm from spindle, reposition arm on spindle where you want it to rest, refit nut.
Posted: Tue Jun 08, 2010 6:58 pm
by the edmundator
Wouldn't that make it try to wipe the bonnet?
Posted: Tue Jun 08, 2010 7:04 pm
by Birdy
You adjust it on the top of the wiper motor itself, last time i tried it was a bit tricky to get it sat right on the screen tho
Posted: Tue Jun 08, 2010 10:44 pm
by PeteGLi
PeteGLi wrote:If I understand you right - you want the blade to rest on the driver's side rather than the passenger side when it comes to rest.
the edmundator wrote:Wouldn't that make it try to wipe the bonnet?
Um, now that you mention it - yes :focus:
Birdy wrote:You adjust it on the top of the wiper motor itself, last time i tried it was a bit tricky to get it sat right on the screen tho
As Birdy says, you have to unscrew the short arm from the motor spindle and rotate that arm until the wiper is in the position you want. It can be a bit trial and error to get it right.
Posted: Wed Jun 09, 2010 6:23 pm
by #Riggs#
Thanx guyzz I will try this at the weekend
:pilot:
