Steel Head Gasket
Posted: Tue May 05, 2009 4:42 pm
by Risocco
Hi guys, just out of curiosity, what are the advantages of using the above over standard? I'm guessing they can take more of a pounding than cork. But do they mess about with compression ratios ect too?Thinking of getting one as I'm planning a bit of tuning in the comming months, just looking for advice really.
Cheers in advance as always guys :good:
Alex
Re: Steel Head Gasket
Posted: Tue May 05, 2009 4:53 pm
by scalainj
They can be tightened down harder, are ultimately thinner, and will increase compression. For me it handled much more pressure and stopped the blow by i was getting with the standard gasket
I've been using them for years - Replaced it about 6 months ago after 5-6 years mainly as i grenaded the old block
Andy
Posted: Tue May 05, 2009 4:59 pm
by Risocco
Hey cheers for the quick reply Andy. So you would recomend one then matey? Car will be a daily driver but with a view to a few track days in the future.
Are they re-usable too? Also what are the cost of them please?
Cheers again
Alex
Posted: Tue May 05, 2009 5:19 pm
by scalainj
I would recommend as i had no choice because my engine lunched 3 head gaskets in a row
I use the 5 layer steel gasket as fitted to G60s and the like but non VW original - i think it cost me £23 or similar
Mines a daily - did quite a few track days with it in - got about 70k from it
No idea if they are re-usuable - i choose not to as my bottom end was gone
Andy
Posted: Tue May 05, 2009 5:34 pm
by Risocco
Awesome, thanks a lot mate. Where did you get yours from? Was expecting three times the price so it would be rude not to invest in one.
Alex
Posted: Tue May 05, 2009 7:34 pm
by scalainj
John Bowles VW in Tunbridge Wells but i suspect they come from GSF or the like
I'm seeing him in the morning so i'll ask if you want
OE gaskets are circa £80 a go
Andy
Posted: Tue May 05, 2009 8:15 pm
by Risocco
If you would dude I'd really appreciate it :beers:
Be a few pay days till I make the purchase but nice to know where to get them from
Thanks for all your help dude
Alex
Posted: Mon May 11, 2009 11:49 am
by scalainj
Right
Prices quoted
VW original £55
Replacement £40 (GSF)
Andy
Posted: Mon May 11, 2009 6:41 pm
by Risocco
scalainj wrote:VW original £55
Andy
Sweet, cheers dude. Take it they are listed under G60?
Alex
Posted: Mon May 11, 2009 7:03 pm
by scalainj
Risocco wrote: Sweet, cheers dude. Take it they are listed under G60?
Alex
Indeed
Some things with these gaskets
1. Check the water and oil ways against your current gasket. On mine other than slightly different hole sizes they matched up but that would be a schoolboy error
2. Tightening. First time i followed the standard Haynes/Bentley generic torque settings and on starting a beautiful mist of oil blew out the back onto the manifold bit like if you haven't got the last 1/4 turn on a fuel line union on a K-jet. So i tightened it down further following the sequence about another 1/2 turn ish on each and that did it.
Second time i went straight for the extra 1/2 ish each . All was fine but i did get a little oil blow so a tweak here and there stopped it. Its a bit trial and error to be fair.
3. 10 bolts 1/2 turn extra with a 3 foot breaker is hard work. Have 3 Weetabix
4. 1st time round i used (and i can't remember what they were) 'upgraded head bolt'. 2nd time i didn't and so far no apparent difference.
Andy
Posted: Mon May 11, 2009 7:13 pm
by Risocco
You are a gent Andy, thanks so much for all your advice and effort :good:
Alex
Posted: Wed May 13, 2009 11:38 am
by scalainj
You are more than welcome
Andy
Posted: Fri Jul 03, 2009 10:53 pm
by Ian Carvell
Anyone know what the compressed thickness of the G60 steel head gasket is in comparison to the standard gasket....just wondering if it improves compression ratio?
