Reversing lights not working :(
Posted: Mon May 17, 2010 9:36 pm
by eefy
Backed on the drive tonight and was told by the other half both reversing lights were'nt working checked the bulbs both seem fine, checked the fuse, again no problems
all i can think is the switch for the gear selector is faulty, so my question is, is this likely and if so where is it and how do i get to it??? Haynes is useless
Re: Reversing lights not working :(
Posted: Mon May 17, 2010 10:15 pm
by ianaudia4
The reversing light switch is on top of the gearbox, should have 2 wires going into it. Be fortunate that it isn't the same switch as on an early injection model with gear change meter, these are £35 plus VAT!
Posted: Tue May 18, 2010 8:00 am
by eefy
Cheers mate, so its easy to get to then :) will have a look tonight and get the mulit meter out
Posted: Wed May 19, 2010 7:26 am
ianaudia4 wrote:gear change meter
Posted: Wed May 19, 2010 9:42 am
by ianaudia4
On early MK2's (my Storm being one of them!) there is a gear change and fuel economy meter within the clocks. The reversing light switch and this gauge are combined and as I said they are £35 plus VAT from the dealers.
Posted: Wed May 19, 2010 11:49 am
i've got one of those fuel economy meters (NOS) in a box on my desk! i thought it just worked on vacuum to give approximate mpg?
Posted: Wed May 19, 2010 8:47 pm
by ianaudia4
It probably does work on vacumn for the mpg but it has an orange light that comes on to tell you when to change up!
Posted: Thu May 20, 2010 11:45 am
by james butler
ive got the same problem. the wires going to the multiplug connecter on the switch have been cut and replaced with female spade conecters, these keep rusting up and giving me a bad conection, because if i wiggle the wires the lights come back on. :ire:
Posted: Thu May 20, 2010 5:49 pm
by Funky Diver
I might be able to sort you out the multiplug and some heatshrink if you need it? How handy are you with a soldering iron? If not, and you can wait a wee while, I'll pull out the whole loom and you can have that...
Posted: Fri May 21, 2010 10:10 am
by james butler
Funky Diver wrote:I might be able to sort you out the multiplug and some heatshrink if you need it? How handy are you with a soldering iron? If not, and you can wait a wee while, I'll pull out the whole loom and you can have that...
yes plz that would be fantastic. yeah im ok with the solderin iron, (not fantastic but im up to the job.)
cheers
james
Posted: Thu May 27, 2010 3:00 pm
by jbo
If anyone needs one if got a working switch which includes all the mfa connections.
£15 posted
Posted: Tue Jun 01, 2010 8:19 pm
by dozzum
The ones for the mpg gear change light are just to stop the light coming on in 5th gear.
Posted: Fri Jun 04, 2010 7:01 am
by james butler
cheers for the loom funky driver, i got the part yesterday. ive now got working lights :hugegrin: now i wont be hitting my gateposts anymore when reversing onto my drive. :yahoo:
Posted: Fri Jun 04, 2010 9:59 am
by Funky Diver
Sweet, glad to be of assistance matey :)
