Hi All
Picking up an ABF engine at the end of the month with all wiring ecu, driveshafts gbox etc but will my original 8valve clocks be compatible or will i need to change them?? If a change is needed would it have to be MK3 Golf GTI clocks?
ABF engine but what clocks?
Re: ABF engine but what clocks?
use the mk2 golf 16v speedo pod. Make sure u get the one with the 2 connectors so the mfa and all that work..
Can use the rocco ones if you want..One of the main reasons to change is the rev counter red line is lowwer on the rocco being an 8v
