vdo voltmeter
Posted: Fri Apr 30, 2010 11:57 am
by type53b
question......when wiring up a vdo voltmeter should i wire it direct to the positive/negative posts on the battery or to the fusebox?
Re: vdo voltmeter
Posted: Fri Apr 30, 2010 12:30 pm
by jbo
To the fusebox matey. Jsut to the left of it you will see loads of spade connections, wire the negative there. The positive wires into a switched positive. If you flip th efusebox down and look to the far left there are some spade connectors that are live when the igntition is on. Check with a multimeter.
Jason
