16v - Join the dots anyone? Please help!
Posted: Tue Apr 27, 2010 9:45 am
by jbo
Hi all,
I have finally got my 16v back form the garage with everything done bar the wirign on the head! I have had a go at it myself but im pretty sure i've got connectors and all sorts in the wrong places. I have been searching online for hours and hours and hours and am yet to find an image or guide explaining which wire connector goes where in a simple laid out format. If someone can help then I will make one! :hugegrin:
Below is a pic I found from a forum. It mentions digifant but this can be ignored. I just need to know what goes where. For example-
#4 - Two Pin Connector - Yellow/Blue Wire & Green Wire
#3 - Single Spade - Blue/White Wire
If someone can check there own wiring asap it would be hugely hugely appreciated. Im still waiting on a connector for the dizzy which is also listed on the "parts wanted" section. Please please please help someone! :dash:
Re: 16v - Join the dots anyone? Please help!
Posted: Tue Apr 27, 2010 12:38 pm
by jbo
Ok here is what I have come up with so far from a bit more searching -
#1 - Single Spade Connector - Blue Wire
#2 - Single Spade Connector - Yellow Wire
#3 - Single Spade Connector - Blue/White Wire
#4 - Two Pin Connector - Green/White & Red/Black Wires
#5 - Single Spade Connector - ???
#6 - Single Spade Connector - ???
#7 - Not Present
#8 - Single Spade Connector - ???
So it's only #5, 6 and 8 I am after. Once I have these i will be sorted. :hugegrin:
Jason
Posted: Tue Apr 27, 2010 10:32 pm
by jbo
Anyone at all?
Posted: Wed Apr 28, 2010 9:18 am
by Chaps
Ok.... back in a min, i'm going to have a goosy gander at the engine in the golf.
Posted: Wed Apr 28, 2010 9:30 am
by jbo
Chaps wrote:Ok.... back in a min, i'm going to have a goosy gander at the engine in the golf.
Wooooo!!!!!!!! :hugegrin:
Posted: Wed Apr 28, 2010 9:55 am
by Chaps
Not the same diagram, You posted this pic up a while back Jbo, my golf 16v KR engine doesnt quite look the same as your picture because i'm using a 16v coolant flange.
Cold start valve = black/green & white/blue with BLUE CLIP
Coolant Temp sensor = red/green SPADE (my sensor is a spade one, unlike your 2 pin clip)
Warm Up Reg = brown & white/red WHITE CLIP
Oil Pressure senders 1 = yellow SPADE
Oil Pressure senders 2 = blue SPADE
Sensor at the back of head (top right above the oil temp sendor lable) = black/green SPADE
Oil Temp Sensor (to the left of the lable) = blue/white SPADE
Thermotime Switch (to the left of the lable) = green/white & red/black BROWN CLIP
What looks like a sensor above the thermotime switch lable = This is actually a bolt hole which holds a steel water pipe in place, this water pipe feeds the heater matrix
ECU Temp sensor = yellow/red SPADE
I know its not exactly the same as your engine but hopefully it will help.
Chaps :good:
Posted: Wed Apr 28, 2010 10:24 am
by jbo
Your awesome! Thank you so much. I will book it in the garage thsi evenign to sort the fuelling anf then it should be done! :hugegrin:
Posted: Wed Apr 28, 2010 11:32 am
by Chaps
No probs fella. Give us a shout if you need anymore info and i'll have another look.
Cheers.
Posted: Fri Apr 30, 2010 9:11 am
by Chaps
Is it working?!?!?
Posted: Fri Apr 30, 2010 9:27 am
by jbo
Well......
Your wire colours were spot on identical to mine so I know that's not the problem but its still wont start. It fires for about a half second then dies. I pulled out one of the injectors while turning it over and nothign happened. I've checked the main and lift pumps with no luck. It's so close now I just put it back in the garage this morning so hopefully they can work it out.
It was fun even being towed in the car ha lol. :hugegrin:
Posted: Fri Apr 30, 2010 3:56 pm
by MikeH
Which 16v engine is it, and what management are you running it on? A bit more info would help.
If it's an ABF on digifant (as your diagram implied) then what's the part number on the ECU?
Posted: Fri Apr 30, 2010 4:05 pm
by jbo
It's all working now! It turns out there was no petrol in as it was all leaking out the lines. All has been fixed and the garage says I can pick up after work. Woooooo!
I will def update my bild thread this weekend! :hugegrin: Thank you very very much for getting the wiring for me. Ive got a nice 15 mile striaght on the way to a house party this eveing! Ohhh yes!
Jason
