Replacing suspension Help
Posted: Thu Apr 15, 2010 6:31 pm
by yourmatedave
Hi guys, replacing the shocks and springs on my 87 scala for the GSF Boge gas ones under reccommendation. Howevere, as im sure someone will be aware, there is a bolt described as the lower strut-to-wheel bearing housing lockbolt that needs to be replaced on the front. Does anyone have a link to the part or part number as I can't seem to find it anywhere? thanks
Dave
Re: Replacing suspension Help
Posted: Thu Apr 15, 2010 6:41 pm
by Funky Diver
Part 17 or 18?
17
133513471 - hexagonal head bolt
18
171407265 - eccentric screw
Click hte image for hte page it's on at VagCat
Posted: Thu Apr 15, 2010 7:59 pm
If it is bolt 17 and 18 you are on about cant say I've ever replaced mine when changing the shocks.
Posted: Thu Apr 15, 2010 9:09 pm
by FuzzyEdges
Yep as mark1gls says 'keep the bolt' use a new nylock nut.
Posted: Mon Apr 19, 2010 9:41 pm
Or you can even keep the nut and use some thread lock.
Posted: Mon Apr 19, 2010 9:53 pm
by ianaudia4
Speak to the dealers, they should still do the bolts, I just got a load of other nuts and bolts last week to replace the bottom of the suspension etc.
Posted: Tue Apr 20, 2010 10:30 pm
by yourmatedave
Also, this is probably a stupid question, but can I fit shorter springs, eg 35mm dropped apex ones on standard length boge gas shocks? Thanks
Dave
Posted: Wed Apr 21, 2010 12:17 am
by Funky Diver
You can, but you shorten hte stroke of hte piston. Ultimately it means that you're not going to get the best ride and will kill the shocks sooner. Best bet if you haven't already is to get a matched shock and spring set.
