I need to change the cam belt on my 1.8 and I can't for the life of me get the bottom pulley off, its the one on the crank with drives the alternator/water pump. It has a 19mm bolt in the middle and 4 alley key bolts around it. The alley key bolts are not in the best shape!
I have not tried heating them up yet as I am out of gas.
I had thought about cutting the plastic case of the leaving the pulley on to change the cam belt, I dunno if this would work or be a good idea though.
Any advice welcome.
