75/76 mph, can i change the gear drive thingy on the end of the speedo cable its a red on at mo just wondered if i could changeto a another vw to suits one that is for 15inch wheels.
speedo gear change
LEEP
speedo gear change
right peeps am running 14/15 inch wheels not the standed 13inch wheels and by my gps am doing 5/6 mph over so say am doing 70mphn the clock is showing
SCIROCCO GT
Member 934
Member 934
- Skyrocketeer
Re: speedo gear change
As long as you're fitting the correct size tyres, the speedo wont be too far out.
They pretty much always read faster than true-speed (up to around 10% I'm told). I wouldn't waste time swapping speedos around as you won't get any more accurate.
I compared the speedo with the Satnav, it was about 10% under what the speedo was reading, both my Sciroccos are the same and they are standard!
Funnily enough the A4 is right on the button.
I would just live with it mate - most older cars tend to be over optimistic with the MPH figures.
