in tank fuel pump 4 injection conversion
Posted: Wed Mar 24, 2010 3:43 pm
by james butler
to convert from carb to injection, can i buy the in tank fuel pump for the scirocco and fit it straight into my petrol tank? or are they different? the golf one is massive and has no chance of fitting.
Re: in tank fuel pump 4 injection conversion
Posted: Wed Mar 24, 2010 4:18 pm
i used a pump from a bmw that looked like this
http://www.bmwpartsweb.com/images/produ ... -BOSCH.jpg and made up a little bracket to mount it under the rear of the car where the accumulator sits on an injection car.
Posted: Thu Mar 25, 2010 11:49 am
by james butler
ahh very nice. down to the scrappy i go! does it matter which bmw i get it from as the pumps will have diferent pressures for different engine sizes wont they? or will the fuel pressure regulater deal with this.
cheers nate
Posted: Thu Mar 25, 2010 1:44 pm
by MikeH
What age is your car? The late Scirocco injection cars have a lift pump in the tank, and a separate pump under the car. This is probably what you want, although I'm not sure if the injection lift pump will fit in a carb car's tank.
Posted: Fri Mar 26, 2010 7:09 am
by james butler
my cars on a h plate so thats 1990. if the fuel pump doesnt fit i could do what nate said and fit an inline fuel pump from a beamer. the only concern i have is the pressures the different pumps will give out as i dont want to damage anything longterm like the pressure regulater
Posted: Fri Mar 26, 2010 8:10 am
i got a pump from an old 535i. it worked fine, so that's as in depth as i though about it. just ripped one off the first car i came accross
Posted: Fri Mar 26, 2010 9:04 am
by MikeH
james butler wrote:my cars on a h plate so thats 1990. if the fuel pump doesnt fit i could do what nate said and fit an inline fuel pump from a beamer. the only concern i have is the pressures the different pumps will give out as i dont want to damage anything longterm like the pressure regulater
I can't see how you'd damage anything. There are plenty of people running kjet pumps on lower pressure systems. The regulator takes care of it.
Posted: Fri Mar 26, 2010 1:41 pm
by james butler
ok just checking. i cant wait to get cracking on it. its goin in 4 mot 2nite so im gona see how that goes before i do anything, im gona have to strip and rebuild the abf lump first, so fitting mite be a while off before doing anything.
cheers again for all your info
james
Posted: Wed Mar 31, 2010 9:54 pm
by The Autoad
The lift pump will fit your tank no problem. The 55 litre tank is the same unit on both carb and injection cars. Its only the earlier cars that have different tanks between carb and injection, and a lift pump will still fit an early carb tank anyways...
Posted: Sat Apr 03, 2010 12:52 pm
by Boumsong
I've converted to injection from a carb'd car and I'm currently running a single fuel pump mounted up in the scuttle..Works perfectly well.
