Wiring in oil pressure and water temperature gauges
Posted: Tue Mar 23, 2010 5:20 pm
by walkinginperu
I've had a look on the FAQ which has an easy guide to what relay pins do what. What I need to know is how to attach wiring to the back of the fuse box without screwing anything up? I guess i probably want my switched lives to go through a fused pin? And am i splicing wires or fixing to pins at the back of the fusebox? Earths are relatively simple i guess, just attach spade connectors to the collection of earths on the right of the fusebox. :help:
Re: Wiring in oil pressure and water temperature gauges
Posted: Thu Mar 25, 2010 10:48 am
by Boumsong
Could run them independant of the fusebox and just have an inline fuse in the wire instead. I have a set-up like this for my fuel pump at the minute, works well.
