and here's the engine:
This is a 2.0 litre block (code ACE) so it’s from an Audi. It has the Audi sump on it, will I need to change this over for a transverse engine sump (from my 1.8 block?), and also will the oil pickup be in the right place?
I've just ordered a Megasquirt 2 ECU from Extra EFI (highly recommend this guy, he's very helpful).
Still need to get hold of quite a lot of bits though. The bit that I think I’m going to struggle with is the fuel system. What do I have to do to the fuel lines and how do I sort out the fuel pump? Do I need a lift pump and then a fuel pump or can I just mount a pump somewhere and hook it all up?
Do i need an ISV with this engine or can I get by without one and get a blanking plate for the manifold? Also do i need to run an oil cooler?
Sorry for all the questions, I’ve not done an engine swap before.
