I have just changed my instrument panel on my mk2 scala for a mk2 golf GTI... it is the correct one so I believe.... 2pin with MFA *140MPH clock*
Everything works ok except I have no fuel gauge.
I dont think my original one has a fuel gauge vacuum tube - certainly didnt take it off while removing it and the golf one doesn't seem to have anywhere to put one?
Any ideas if this is gonna be a speedo fault, wiring loom difference or just the wrong unit?
John
Speedo change... no fuel guage?
Re: Speedo change... no fuel guage?
fuel gauge vacuum tube ???????
are you refering to MFA, economy meter or fuel level?
checked the pcb ain't damaged?
- vwjohn81
Hey - its the fuel level..... think I have found the problem but not had time to sort it - the connections on the loom to the instrument panel are in a slightly different order than my original unit - so think gonna have to move the wires.
