Mintex pads?
christhemann
Mintex pads?
Post by christhemann »
Hi,
Need to change front pads on the 1.8 Scala carb. Anybody had good experience with Mintex ones?
Specifically these on ebay:
http://cgi.ebay.co.uk/VW-SCIROCCO-1-8-G ... 2a02b7eef8
Are they any good? (the seller and the pads!)
Cheers,
Chris
1989 Helios Blue Scala
Re: Mintex pads?
never had any experience of the seller. mintex pads get a thumbs up though
Rick84
Re: Mintex pads?
Post by Rick84 »
Mintex extreme are shocking, don't get them. They will fade away to nothing after two minutes of quick driving if you have 239mm discs. However Mintex M1144s are excellent and pretty fade resdistant I've found. I'm on EBC yellow stuff at the moment, seem good but not really worn them in yet.
Brunty
Re: Mintex pads?
Post by Brunty »
Rick84 wrote:Mintex extreme are shocking, don't get them. They will fade away to nothing after two minutes of quick driving if you have 239mm discs. However Mintex M1144s are excellent and pretty fade resdistant I've found. I'm on EBC yellow stuff at the moment, seem good but not really worn them in yet.
Mintex stopped making the Xtreme range a couple of years ago, so no worries there. I only really use M1144 myself.
Brunty
filmidget
Re: Mintex pads?
Post by filmidget »
Aaaah, Mintex... Never been the same since they dropped the M171's to go all new-fangled asbestos-free with these 'ere M1144's.
T'was all fields here once you know...
