16v wiring / head
Posted: Mon Jan 04, 2010 11:18 pm
As im aware there is going to be a few 16v's being built i thought id stick this up as a sticky,for people to relate to wiring up the all important oil lights water sensors oil temps and the go go the ecu..
the yellow wire to the high pressure switch coloured white , and blue wire to the low pressure switch ,brown or black coloured
I will write up on how you get the feed to your ecu shortly.
