When starting
Posted: Fri Nov 20, 2009 12:24 am
by gearyboy
When starting my scirocco i have to give it a bit of gas, if i start the engine without, it turns over and dies. is this just a normal thing or is there something i should be looking at? Runs perfectly otherwise just needs a bit of throttle when starting.
Matt
Re: When starting
Posted: Fri Nov 20, 2009 8:45 am
by wasted
Pretty normal, I'd say. Starting from cold or hot?
Re: When starting
Posted: Fri Nov 20, 2009 9:45 am
by Brunty
The instruction manual even states to use a small amount of throttle when starting the engine.
Re: When starting
Posted: Fri Nov 20, 2009 6:59 pm
by ianaudia4
Brunty wrote:The instruction manual even states to use a small amount of throttle when starting the engine.
They did on the early versions (ie my Storm manual), the later manual says you shoukld not need to :!:
Re: When starting
Posted: Fri Nov 20, 2009 10:28 pm
by stu.gtx
If you stick some decent fuel system cleaner in it like slick 50 it might help. It did on mine a few years ago, worth changing the fuel filter too.
Re: When starting
Posted: Fri Nov 20, 2009 10:41 pm
by gearyboy
wasted wrote:Pretty normal, I'd say. Starting from cold or hot?
mainly cold
Re: When starting
Posted: Fri Nov 20, 2009 10:42 pm
by gearyboy
stu.gtx wrote:If you stick some decent fuel system cleaner in it like slick 50 it might help. It did on mine a few years ago, worth changing the fuel filter too.
cheers il give it a try
Re: When starting
Posted: Sat Nov 21, 2009 11:29 am
by bluestreak56
Is it an injection or carb?
If injection are the symptoms similar to this?:
http://www.sciroccoregisterforum.co.uk/ ... f=12&t=669
Re: When starting
Posted: Mon Nov 23, 2009 8:01 am
by gearyboy
bluestreak56 wrote:Is it an injection or carb?
Its injection, no its not like the above thread, just needs a bit of gas to start, once going its runs great. Without gas it starts and stops straight away. Ive only had the car two weeks but since posting this thread i have noticed it is cold start only
