Page 1 of 2
camber bolts on scirocco
Posted: Fri Nov 13, 2009 12:28 am
by johnypud
Changed my front spring today and realised that the pinch bolt on the strut was atucally the camber type, just wondering if this is standard? as rest of suspension is completly standard
thanks
Re: camber bolts on scirocco
Posted: Fri Nov 13, 2009 7:12 am
by markh
Theres two bolts holding the strut to the hub, the upper one is indeed a camber bolt.
Posted: Fri Nov 13, 2009 12:23 pm
johnypud wrote:Changed my front spring today and realised that the pinch bolt on the strut was atucally the camber type, just wondering if this is standard? as rest of suspension is completly standard
thanks
Now means you need to find somewhere that can set up the camber for you.
Posted: Fri Nov 13, 2009 6:30 pm
by fonzooorooo
frost restoration do a magnetic bubble gauge that you stick to the disc for setting camber. just so you know.
Posted: Fri Nov 13, 2009 7:43 pm
by dozzum
just set em on the midpoint, thats what ive dun with mine, no issues so far.
Posted: Sat Nov 14, 2009 12:39 am
by johnypud
fonzooorooo wrote:frost restoration do a magnetic bubble gauge that you stick to the disc for setting camber. just so you know.
nowt wrong with rack ot eye !!!
Posted: Wed Jan 13, 2010 7:35 pm
by liam
surley if you use a magnetic camber gauge and the cars on a jack thats gonna put the reading out because its not on a level?
Posted: Thu Jan 14, 2010 8:16 am
by Jay4424
Yep, when setting up camber the car has to be "at ride hight" ... if you want to d othis with out hte wheels on then stick 4 jacks, one under each whishbone... rithg at hte end so as the car sits down where it would... but even this won't be truly right, you could always make a rig that extends out from teh hub!!!
...the local expert to me about this is Fonzooroo, hes made his own jig and otehr such impliments of calibration!
Jay.
Posted: Thu Jan 14, 2010 10:00 am
by liam
hhhmmmm....
measure twice cut once? with wheel on use the magnet level to take a reading and note degree, then jack up, take wheel off and measure again. If with wheel on the cambers say -3 but with wheel off its -4 just take the 4 as really a 3 and adjust from their.
mine needs doing, the bald patch and odd looking angle tells me so!
Posted: Thu Jan 14, 2010 10:14 am
by Brunty
I made my own camber checking device with a plumb bob, some angle iron and a couple of bolts...
It's only going to work if the car is on perfectly level ground though.
Posted: Fri Jan 15, 2010 5:32 pm
by liam
anyone know if the camber bolt has to be changed for a bolt with a different degree or it just adjusts the camber as you turn it?
gonna have a crack
cheers
Posted: Fri Jan 15, 2010 6:39 pm
by Brunty
It's eccentric so you just turn it as much as you need to.
Posted: Mon Jan 18, 2010 8:34 pm
by liam
thanks for the help, this site is great!
just wanted to know if anyone knows what size bolt they are so i buy the tool before getting the wheel off
thanks again
Posted: Mon Jan 18, 2010 9:35 pm
by Tim_R
17mm both ends for nut and bold head.
Posted: Tue Jan 26, 2010 8:28 am
by fonzooorooo
forgot about this thread.
re the magnetic gauge, it's a case of use on level ground, then lots of measuring.... height of body to ground, and hub to ground, then removing the wheel and achieving the same numbers using the jack. I ended up jacking at the outermost extremity of the brake disc/hub as jacking under the balljoint (where I expected it'd work, before I tried) would not result in the correct ride height on both sides of the car. (leverage of suspension)
Suppose this is the perfect application for alloys with tiny spokes... just reach through the wheel and stick the gauge on, then attack from behind with the sockets...
No such easy life with stock steelies though...
Once it's on though, the gauge is calibrated down to 1/2 a degree (i think, from memory over a year ago!), and with it being a bubble, you can see smaller increments.
