Kick in the back
Posted: Wed Nov 11, 2009 3:25 pm
by Flash
My Kjet Scala has a very uncomfortable new vice as of yesterday. When changing up and then applying throttle the engine cuts out for a moment - maybe one second - and the jolts back to life with the obvious kick in the back. I can't see anything loose or disconnected under the bonnet. The idle has dropped 200 and power is down but not by much. New tank and filler neck fitted recently so I'm fairy sure its not dirty fuel. Any ideas? :scratch:
Re: Kick in the back
Posted: Thu Nov 12, 2009 12:35 pm
what are your ignition components like? vws can be quite hard on them. i still carry a dizzy cap and arm on my truck as they seem to fail quite regularly
Posted: Thu Dec 03, 2009 3:02 pm
by Flash
Found the fault when my son, Brunty came to visit. Bit embarrassing really. :oops: The dizzy was loose and turning as the engine revved. Tightened it up, reset timing and replaced dizzy cap, rotor and plugs for good measure. Job done :)
Posted: Fri Dec 04, 2009 9:21 am
by Brunty
:beers:
Posted: Sat Feb 13, 2010 10:07 pm
by towey86
I Had a problem like this with my scala...
It was the in tank fuel pump. The main pump was struggling to pull the petrol it needed through. I replaced both internal and external pumps and it then ran perfect again. :mafia:
