Been a long time since this thread updated.
Obviously the COVID years has seen much less use than hoped for but been keeping on top of the maintenance with thanks to The Phirm.
During and since 2019 lots of key jobs done - here is the latest rundown from my spreadsheet
Item/Miles/Date
accumulator 96117 27 April 2019
auxillary belt 97021 19-Oct-2019
battery 97379 24-Dec-2019
brake cylinders 97021 19-Oct-2019
brake caliper 98062 11 July 2022 offside caliper changed
brake discs 87836 25-May-2005 all brake hardware checked -OK 3 Dec 2021
brake fluid 98062 11-Jul-2022
brake hoses 88453 31-Aug-2005
brake lines 91134 4-Jan-2013
brake pads 87836 25-May-2005
brake shoes 91134 4-Jan-2013
bulkhead panel 91191 24-Jan-2015
cambelt and tensioner 97948 3-Dec-2021
clutch 91846 21-May-2016 skimmed flywheel and new input shaft seals
clutch cable 94043 17-Mar-2017 434 872 gemo
clutch release bearing and push rod shaft 94311 13-May-2017
coolant 96117 28-Apr-2019
coolant bottle 91345 1-May-2013
cv gaitor inner os 97621 19-Jun-2020
cv joints 91846 21-May-2016 regreased
cylinder head gasket - g60 spec 94888 3-Feb-2018
dizzy cap and rotor 94888 3-Feb-2018
exhaust 91131 26-May-2012 manifold repaired Feb 2018
front bearings checked 27 February 2016
fuel filter 94043 17-Mar-2017
fuel lift pump 96117 28-Apr-2019
fuel pump 96117 28-Apr-2019
fuel tank 1-Nov-2005
gear linkage bushes 94311 13-May-2017
gearbox oil 94177 22-Apr-2017 level checked ok 3 Dec 2021
handbrake cables 97621 19-Jun-2020
head gasket 31-Jan-2018 oil pressure tested Feb 2018
heater matrix 91846 21-May-2016
injector seals 91846 21-May-2016 injectors cleaned
k and n air filter 78353 2-Apr-2002 self check
ns ball joint 99621 19-Jun-2020
oil change 97448 7-Mar-2020
oil filter 97448 7-Mar-2020
oil pump original? all fine, checked Feb 2018
os steering rack gaitor 91131 26-May-2012 os
plug leads 91191 26-Jan-2013 all fine 3 Dec 2021
radiator 1-Aug-2005
rear bearings checked 27 February 2016
rear bushes 22-Aug-2008 checked 27 February 2016
rocker gasket 94888 3-Feb-2018
seal 020 301 227D
spark plugs 97488 7-Mar-2020
speedo cable 91198 7-Mar-2015
speedo seal 97948 3-Dec-2021
starter motor 91846 21-May-2016
sump gasket 91645 27-Feb-2016 all fine, checked Feb 2018
suspension 91191 12-Apr-2014 new AP coilovers
thermostat 96117 28-Apr-2019
top mounts 30000 31-Jul-1991 all fine 3 Dec 2021
track rod end os 97621 19-Jun-2020
track rod end ns
tune kjet 97448 7-Mar-2020
tyres front and rear 91846 21-May-2016
voltage regulator 94888 3-Feb-2018
water pump 96117 28-Apr-2019
Wipers front 95250 21-Apr-2018
Wishbones cleaned and repainted 3 Dec 2021
A20 GTX - BRM152 2-litre GTX - long term affair
The final chapter.
End of an era.
The BRM off with its new keeper. End of an era.
