problems bleeding mk1 scirocco brakes....
Posted: Mon Nov 02, 2009 6:57 pm
by malmac
Hi, almost got my mk1 scirocco GTi up and running after being in bits in my garage for over a year, got it started ok but brakes need bleeding as rear axel's been off for welding so all disconnected etc. Problem is when i got round to bleeding o/s/f brake no fluid was coming out at all. So at the minute the brake pedal goes to the floor with no stopping power at all. Can anyone shed any light on how to cure this, also is there a specific procedure when bleeding all corners of the car eg front first etc.......
Any help greatly appreciated.
Mal.
Re: problems bleeding mk1 scirocco brakes....
Posted: Mon Nov 02, 2009 7:13 pm
by Mike the Founder
I believe haynes says start at the furthest point away and end at the nearest.
Try using a pressure bleed system. They are cheap enuf.
and never press your foot all the way to the floor if you do use your foot. You'll screw the seals up inside the cylinder especially on old systems...
Posted: Tue Nov 03, 2009 6:08 am
could be that the ruber pipe has collapsed inside. you could try unscrewing the bleed nipple and leaving it open for a few hours and see if it gets moving by itself - just make sure you keep an eye on the resevoir ;)
Posted: Tue Nov 03, 2009 4:26 pm
by malmac
yeah, was thinking of getting a pressure bleeder, think i'll have another go over the weekend. Thanks for replies, I'll certainly keep them in mind.
cheers
mal.
Posted: Wed Nov 04, 2009 12:53 pm
make sure you don't run the pressurised bleed kit at higher pressure than the book says. if you do you risk inverting the seals in the master cylinder. i had a similar problem to you on a mk2 astra years ago. couldn't even get it moving with the pressure kit, so i upped the pressure to 40psi. it got the fluid moving, but i then had to walk to the scrappy for a new master cylinder.
Posted: Sat Nov 07, 2009 4:45 pm
by malmac
'twas indeed the brake hose which was knackered, cheers nate.
all's well that ends well................
Posted: Thu Nov 12, 2009 12:30 pm
i'm gonna have to be careful. people might start thinking i know what 'm talking aout
