Speedo cable
Posted: Sun Apr 12, 2009 1:32 am
by ianaudia4
My new speedo cable has just stopped again!
I onlt fitted it and a new drive that goes into the gearbox 2 weeks ago.
Out for a blast tonight, stopped again.
Any advice?
Re: Speedo cable
Posted: Sun Apr 12, 2009 11:45 pm
by The Autoad
check that the plastic drive gear at gearbox end hasn't come loose and fallen into the box -remove cable at gearbox to check.
or/and
did you use the correct plastic clip at the clocks? if not the cable may have worked loose.
I hope its the latter.
