Vauge steering
larky
Vauge steering
Post by larky »
I've noticed quite a bit of play in the steering wheel, I've thought about replacing the steering rack bushes first, but do you think I might need a new rack, or are there other options
Sam
MrP
Re: Vauge steering
Post by MrP »
Personally from what I've experienced and heard/read the rack's in these never really fail (on the rare occasions that they become loose they can be adjusted)
I'd be checking track rod ends, wishbone bushes (I'd be checking these first!), suspension top mounts, wheel bearings etc way before I'd even consider the rack.
Hope that helps.
Rich.
larky
Re: Vauge steering
Post by larky »
MrP wrote:Personally from what I've experienced and heard/read the rack's in these never really fail (on the rare occasions that they become loose they can be adjusted)
Hope that helps.
Rich.
Thanks Rich
Thats what I was thinking aswell
Re: Vauge steering
assume you mean rotational free play at the wheel? if yes, as above. if no, steering column bushes
