Fuel filler neck
roccodan
Fuel filler neck
Post by roccodan »
Mine is all rusty and leaking,would it be possable just to cut it just below the filler and replace the steel pipe with rubber,can anyone foresee any probs with this?
Niall
Re: Fuel filler neck
Post by Niall »
Might be worth checking here before you do that buddy.
http://sciroccoregisterforum.co.uk/carf ... =15&t=1242
