Quick Shift Kit... To buy or not to buy!! (now bought)
I'm toying with the idea of reducing the throw between gearchange, I would like to tighten everything up at the same time. My gearbox is great and finding gears is quite easy.. just wanna have a smoother, quicker, shorter gear change
Any advice?
Shaynan
86 1.8 8v GTX
Any advice?
Shaynan
86 1.8 8v GTX
Re: Quick Shift Kit... To buy or not to buy!!
I had one on the old car and will get another for this one.
Takes a bit of getting used to but well worth it
have this plus a weighted rod (to allow gear lever, with its LHD origins, to sit away from passenger seat) on all the mk2s = great upgrade.
Used them on 2 previous cars, they are a great mod i think and give a more positive gearchange..
Also have one fitted to mine,bought off here,find it great,very fast changes ! Apart from when the pin comes out,and you have to put a new one in,when the engine is hot !
Where does one purchase such a thing?
Ping!the edmundator wrote:Where does one purchase such a thing?
http://www.trimsport.co.uk/engine.html
And as if by magi the shop keeper appeared.
Think this is the one I had fitted.
Nice one guys lots of replies. How easy are they to fit?
- b5byt
Very simple ;)
1984 Scirocco Storm Cosmos Blue < Body has really had it, if you need parts off it let me know < Going.
1986 Scirocco Scala (Rocco-Jocco's old one) Having some life put back in to it
2001 Carbon Black E39 M5
2008 Carbon Black E60 M5
try 'c and r' too - see discounts section.
First mod I did on both my Roccos, as soon as I got them.
Got mine and the powershift kit (weighted rod) from ABD Racing: http://abdracingwerks.com/Merchant2/mer ... Code=40.10, distributed back then by Impossible Performance.
Tempest
Tempest
My Mk1 Rocco, Rado and 928
Corrado Club of GB Events Manager
Mr Funk wrote:Ping!the edmundator wrote:Where does one purchase such a thing?
* Will this one fit my 1.8 8v GTX? Also where can I get the rod aswell?
GLK661005 NEUSPEED SHORT SHIFT KITS Neuspeed 3-Part Short shift gearlinkage SC £129.00
GLKACCWS95568 LAKESPEED GEARBOX Gearlinkage Counter Weight Shaft Golf Mk1 and Scirocco G1 1.5-1.8 74-84 £31.75
CHECK http://www.candrenterprises.co.uk/selec ... on=Gearbox
ps AVOID the jokers on ebay QUOTING GOLF MK2/SCIROCCO MK2 linkages, they're the wrong ones. you need the mk1 golf versions as per c and r listing amongst others.
GTXTRA wrote:GLK661005 NEUSPEED SHORT SHIFT KITS Neuspeed 3-Part Short shift gearlinkage SC £129.00
I'm going for more for a budget option buddy... £129.00 is a wee bit more than i'd like to spend on my cheap classic ( For Now ) Should I just get the one from trimsport for £20.00?
http://www.trimsport.co.uk/03-10-07_1520.jpg
