When the drivers window is wound down - even a little bit it's quite rattly.
Now that the car is in bits, I was thinking it would be a good time to replace any window guides/seals/scrapers.
So the question is - what'll do the trick?
Rattly windows - mk1
Re: Rattly windows - mk1
Check that there is still the rubbers in the runners inside the door. I had one come out of the runner at the back of the door (near the latch). Its just glued in there.
- Ryan
yep - they're the boys I'm looking at - just wondered if anyone knew which I'm most likely to needPeteGLi wrote:Vintage Rubber ????
Cheersmark1gls wrote:Check that there is still the rubbers in the runners inside the door. I had one come out of the runner at the back of the door (near the latch). Its just glued in there.
I'll try and get a photo of what I'm on about tomorrow.
Finally got round to taking photos,
This is what fell out in my door a few years back. was just the rubber inside the metal runner.
view from top of the door looking down where the window goes. You should be able this with out taking and pannels etc off.
Might be of some help or might not.
