Hi guys, just wondering if anyone could help.
My pads rattle in the calipers. They seem to be in place fine, but there is quite a bit of movement. I can pretty much rattle them. It makes a really unpleasant noise when going over mildly uneven roads. Does anyone have a diagram of the caliper and its bits, are mine missing retaining clips?
Thanks in advance.
Andy
Calipers and pads problem
andyneedham2
Re: Calipers and pads problem
Hi Andy,
I have had this same problem before and i noticed it was missing the thin anti rattle clips on my rocco which can be missing after new pads have been fitted.
They are just thin pieces of metal which locate between the pads and carrier top and bottom of the pad location lugs.
Have a look at your calipers to see if they are missing on your car.If so i have some spare if needed.
Cheers Graham
Cheers Graham
1974 Scirocco TS ,1978 Scirocco GLS, 1980 Scirocco Storm, 1981 Scirocco Gti.
andyneedham2
Ace. I've had a look and it seems I am missing the anti rattle clips. If you have some going I'll take em...
Thanks for the help
Thanks for the help
Hi Andy,
Sure no problem mate.
Let me know your address and i will post them to you.
Hi Andy,
I will get them in the post today for you.
Regards Graham
Regards Graham
andyneedham2
You sir are a legend. Much appreciated,
Andy
Andy
