Sorry this is a bit long and windy I’m a novice so sorry .
I tried to remove the steering column and it’s tube housing today but failed. I was expecting the column to have a ‘leaf spring’ and 2 upper mountings each with two bolts and to remove the steering wheel etc then with the u-Joint nut loosened and the leaf spring removed to be able to wiggle the column shaft out of the u-joint and remove the column housing and column together.
BUT sadly NO, my set-up is different! I have one upper mounting (2 bolts) and a pedal bracket that seems to be part of the column tubing housing. It’s factory but is very different to what I was expecting.
I got as far as removing all the peripherals like wheel and the switch instrument and the bolts for the upper mounting and the hex bolt for the metal thingy with the ignition switch and the clutch pedal. I then suspected that I needed to remove the brake pedal and after that three bolts for the pedal bracket (this does seems to be part of the column tubing). Anyway at this point I stopped because I realised I didn’t know what I was doing and I didn’t want to F-Up massively, so I put it all back together again and thought I’d ask for some advice on here.
If anyone can advise me about removing this type of column that I have tried to describe that would be great! Just to reiterate, It looks to me that my column housing has a pedal bracket as part of it and so at the end its a tube plus bracket and the reason for removing is to replace the bearings.
Thing is I’ve managed to fix quite a lot of issues this summer so I thought I was up for this job but it looks like I’m not that clever after all
Help appreciated, I’m requesting any tips or tricks that I’m missing because I can’t even find a diagram of this set-up in the Haynes. BTW it’s not got power steering and it’s 1992
Also I was intending to replace the u-joint shaft. I took advice from here and got a second hand one that seems fine. Any advice on how to replace that too would be good but it looks from my efforts today that my original Ujoint shaft was just loose and not tightened up enough so i may be lucky here!
At the steering column end UJ, I had a 13mm nut and on the other side that I couldn’t see it had a 10mm bolt head, seems odd? Is that an original bolt? There was also a second 13mm nut so it must have gotten loose at some stage in the past and a two nut trick used to try and keep it tight?
So questions about the ujoint shaft
1- can it be replaced without removing other parts (the access looks very bad to a novice like me)
2- would you detach the steering rack side from the top or bottom of the engine bay? ( the access from underneath even if I get on ramps seems really tight)
3- I don’t understand if this UJ shaft is LHD or RHD or if that matters here but I do have the RHD shaft. Maybe that’s a mute point for this part. Just ignore this question if it’s stupid.
Thank you !
