Horn wiring - Scala
K15NWP
Horn wiring - Scala
Post by K15NWP »
Good evening,
Continuing the recommission of my Scirocco after a significant absence from the road, another question please?
Just a recap first, been a busy few weekends 8-)
  • Fuelling issue - resolved with new lift pump
  • Full service with Syntra oil (10w40)
  • New drive belt (Gates)
  • New timing belt and tensioner (Gates)
  • About to fit another new timing belt as there was some swarf at the bottom of the cover that took the writing off and was audible with the squeak; better safe than sorry!
Ah! Where was I?! Steering wheel
I have a ?Polo (smaller) steering wheel on at the moment
https://drive.google.com/file/d/1El5Zwd ... share_link
I have the original, cleaned since this photo, but am being daft as cannot think which way the brown and black leads go :?
https://drive.google.com/file/d/1kris6 ... share_link
https://drive.google.com/file/d/1R7AUv- ... share_link
Thank you in advance!
‘92 Scala - Alpine White
Daily 2023 Volvo S60 T8 Ultimate
Others like Yugo Cabriolet, Land Rover Series 1 & 3, Lotus 7 and more.
Membership No.1766
GT_II
Re: Horn wiring - Scala
Post by GT_II »
It doesn't matter which way round the black and brown wires are connected - as long as the flag connectors are oriented so that there is no risk they can touch each other accidentally.
K15NWP
Post by K15NWP »
GT_II
Thank you for the swift reply and advice!
Membership No.1766
WreckTangle
Post by WreckTangle »
If you want to be OCD about it, I photographed mine as I took it off.
Personally, I prefer the older, four button steering wheel.
The older steering wheels use a small spline so it is necessary to remove the large spline adapter. Also you need a plastic spacer to place over the steering column to avoid the horn sounding uncontrollably.
K15NWP
Post by K15NWP »
Thank you for calming my CDO :-)
Now, that’s a steering wheel I’d quite like too! I’m going to look at running with the original for a while, now to keep an eye out for the older version; reads like effort, I’ve not been in the interior modification in any of my other vehicles.
Nearly time to plan a winter project for sure!
Thank you
Membership No.1766
