I own a Mk2 Scirocco that has been modified by a previous owner. In terms of modifications, the information I have is very limited as the owner that modified it was a few ago and therefore probably lost through ownership passing it on, however; in terms of engine it has an Audi 80 2.0e litre bubble block, head from a mk2 golf GTI 8v with Ashley four branch manifold. It's had a digifant injection system fitted. Still has distributor and coil, inevitably a lot of wiring has been modified to fit this. Also got the air flow meter which has been set to a happy medium to pass emissions but not running too lean. Hopefully this will give enough baseline to go...
I'm experiencing major issues with power loss (almost like a limp home mode which I suspect this is too retro to have) and a spurious idle. I'm convinced the two are linked but can't be sure. Links of the two issues are shared below although appreciate the power loss one isn't the best so apologies:
Power Issue https://www.youtube.com/shorts/P2D1-scWRtQ
Idling Issue https://www.youtube.com/shorts/32mgaltf9ec
- The idling issue seems to get worse when the car gets up to temperature after 5 mins of driving, it was doing it sporadically but seems to be a more common issue now. When slowing for a junction and dipping the clutch, its enough for the car to stall as well.
- In terms of the power issue, this seems to occur after the idling occurs but isn't limited to this, it can manifest itself in a complete power reduction, with foot to the floor in second the car just sits at 20mph/2k revs with no power and judders until suddenly the issue disappears and it picks up. This can also manifest at any speed, gear or rev range. It also come in the form of whilst driving up through the gears a massive blip (almost like a misfire) before cutting back in
