sill panels
- whiteshark
Re: sill panels
Link:
https://www.ebay.co.uk/itm/154394471325
These are not OEM so may not be a perfect fit, but better than nothing. I would of bought a set as spares but the seller will not post to Northern Ireland. Let me know how you get on. Still might buy a set and get them sent to Scotland and my friend can post them from there.
Available for each side. Good luck.
If your after the plastic outer sill panels, all over the bay or drop me a pm of what your after. But based on the year of your car, i'm guessing your after the sill repair panels.
Re: sill panels
Hi, thanks for reply restoring 84gl it needs rear arches and outer sills I don't know if these are what I need not a panel man myself will check with body shop in morning.Thanks again.
- whiteshark
Re: sill panels
If you need rear arch repair panels, either get a welder that can make cut outs and patch them or get cut outs from a scrapped car. Good Luck!! As yours is a an early model, better getting cut outs if you can. There used to be a guy in Belgium did them, but no more. Could maybe be a club solution / buy option. Was going to enquire with a company in Wexford that make custom body panels. If you drive your car on a regular basis, most common fault in the body work is the rear section below the headlights and the rear arches.
You can still buy a rear section from VW classic , but for the rear arches you have to buy half of the rear of the car and the cost is prohibitive. Or try on the facebook.
Re: sill panels
I have been in touch with Joost he has arches I can purchase waiting for costs p&p etc. just got to find a way around the outer sills now, the mrs won't let me carve up one of our other ones!! thanks for all your help people.
