Cold Start Issue
JOH
Cold Start Issue
Post by JOH »
Hi All,
My injected Scala is taking two or three turns of the ignition to get it started from cold. Seems like fuel is not getting through on first / second turn then fires up fine.
I've heard talk of 5th injector being the culprit although are replacements available? Any suggestions?
Thanks!
Turbogirlie
Re: Cold Start Issue
Post by Turbogirlie »
Hi - did you ever solve this?
Luv Turbogirlie (aka Kaz)
VW Scirocco GTX (DX 1.8 8v) 1985
