E10 fuel in an emergency?
Posted: Sun Sep 26, 2021 10:43 pm
by rosie
My tank’s empty, so no fuel to drive around looking for fuel. Need to get the car to the mechanics a couple of times this week for work on the suspension prior to my MOT retest, plus a few urgent trips.
I’m wondering if I can get away with putting in a bit of E10 unleaded as an emergency measure until the fuel shortage situation settles down? I haven’t been able to find E5 anywhere and at this point am too low to keep searching. E10 is still available in a couple of places. It’s my only mode of transport.
The car has a brand new petrol tank and rubber filler neck.
Any thoughts please?
Re: E10 fuel in an emergency?
Posted: Sun Sep 26, 2021 11:16 pm
by DannyH
I believe Super Unleadeds are E5??
Posted: Sun Sep 26, 2021 11:43 pm
by GT_II
According to VW, only their 1st generation FSI engines (early to mid 2000s) are not compatible with E10 fuel. Do I believe they have done the research on 1980s engines and would I trust it in mine? No, I only fill with Esso Synergy Supreme+ 99, as this is guaranteed ethanol-free in most areas (except Cornwall, Devon, North Wales, North England and Scotland). Do you have a motorway or trunk road service station within easy reach? Fuel companies are reportedly prioritising deliveries there, so it may be worth exploring that option first.
There are 3 potential issues with E10 in older engines: (1) fuel separation due to water absorption in storage leading to corrosion - unlikely to be an issue for a daily driver; (2) corrosion of aluminium components in the fuel system - apparently mainly an issue in high pressure high temperature applications such as those early FSIs, so hopefully not too critical for short term use in Mk2 carb engines, but possibly more of an issue in injection engines; (3) damage to plastics such as hoses and seals - probably not a major issue on late Mk2 Sciroccos, as most manufacturers reportedly switched to ethanol-resistant alternatives during the late 1980s, though the same can't necessarily be said for any after-market components fitted.
So is there a risk to putting a bit of E10 in your carb engine as an emergency measure? Well I guess in theory yes, but hopefully very small.
Posted: Mon Sep 27, 2021 7:15 am
by rosie
Thanks guys. I haven’t been able to find any super unleaded anywhere so that isn’t an option in the immediate future.
I thought if I put in a bit of E10 it would allow me to drive round looking for some E5. I’m on fumes at this point so definitely can’t get to a motorway station.
Can’t believe this is happening in the run up to the MoT retest.
Maybe I’ll take a chance and stick a little bit in.
Posted: Mon Sep 27, 2021 12:37 pm
I guess you will be fine to stick some in as it’s a daily drive and when you can go back to super unleaded.
Posted: Thu Sep 30, 2021 10:25 pm
by rosie
Finally got half a tank of super unleaded in there today so hopefully no damage done.
Posted: Fri Oct 01, 2021 9:32 pm
I’m sure you’ll be alright.
Tesco near me only have super unleaded and no normal unleaded or diesel available so that was ideal for me…
Posted: Sun Nov 07, 2021 4:13 pm
by james butler
dont know if its any good but theres additives for preventing ethanol damage you can add with every fill
time will tell whether ethanol will damage our cars and if additives work
but for the one off fill and use will probably be ok
