High revs problem solved
Posted: Wed Mar 24, 2021 11:16 am
A bit of info for anybody with a fast tick over problem.
I've done a lot of work recommissioning my mk2, which had been off the road for 4yrs,
and although I'd got it running ok (if a bit rough) it suddenly developed a tick over which wouldn't drop below 2100 revs.
I would have suspected the waxstat but I'd fitted a new one already.
I got all ready to refurbish the carb and even bought a 2nd hand pierburg with a manual choke conversion to refurbish off the car and a Haynes carburettor manual...
I'd previously drained down the coolant fitting the timing belt/coolant pump, and thought it was worth checking whether there was a connection here. Was the waxstat getting the heat it needed?
Purged the system of air and revs dropped to a steady 900! I'd had an air lock that isolated the waxstat from the coolant.
I know the waxstat causes so many issues, so thought it might be worth sharing.
