Vacuum sensor connector, how do I fix this?
Posted: Tue Mar 16, 2021 9:40 am
by p in phcas
The wire broke right at the connector. Any suggestions how to fix this or can the connector be disassembled and new connectors fitted?
Re: Vacuum sensor connector, how do I fix this?
Posted: Tue Mar 16, 2021 11:06 am
by GT_II
I think 037906240 will fit - perhaps others can confirm. The easiest option would probably be to buy one second hand with wiring tails attached - there are several on ebay.
Posted: Tue Mar 16, 2021 12:17 pm
by p in phcas
Never messed about with one of those type of connectors. Is a special tool required?
Posted: Tue Mar 16, 2021 12:47 pm
by p in phcas
For anyone's interest - I found this really useful link on the VWVortex forum. Lots of useful VW specific electrical and connector references.
https://www.vwvortex.com/threads/electr ... s.6948714/
Posted: Tue Mar 16, 2021 1:03 pm
by GT_II
To fit new terminals into the connector you would need a non-insulated crimp tool suitable for the terminals used, something like this might do the job:
https://www.ebay.co.uk/itm/0-14-1-5mm2- ... SwLnBX6O69
Splicing a used connector with wiring tails still attached, for example by soldering and shrink wrapping the joint, would be an easier option, albeit not so elegant.
