Mk2 RWD 1.8T
mk2daz
Re: Mk2 RWD 1.8T
Post by mk2daz »
Started to build up the floor again in the middle portion of the car to regain some strength and also in order to suspend the gearbox under its own weight.
Bolted up some porsche 924 discs up the front so i could get some 4x108 wheels on for now and was able to drop the car on the ground again for the first time in a while. Also chucked the front end on!
Rolling with a full RWD drivetrain (minus the propshaft!)
The rear sits pretty nice and has plenty of adjustment in the suspension arms but the front requires some fairly heavy camber adjustments, will poke a bit more with some proper brakes etc fitted but i'm gonna need to look into extending the wishbones and/or modifying the strut top with some adjustable top mounts i think.
Here is youtube episode 2
https://www.youtube.com/watch?v=p4hHInvlaG0
RussGLAuto
Re: Mk2 RWD 1.8T
Post by RussGLAuto »
Epic mate! Well done...
mk2daz
Re: Mk2 RWD 1.8T
Post by mk2daz »
Long delayed update!
Measured up for a custom propshaft and had BAR propshafts in wales make it up for me, great turnaround, 2.5" heavy duty tubing, genuine spicer HD rally UJ's, balanced and ready to go
Fits superb - now officially rolling with a full RWD drivetrain!
Got my bucket seat rails mounted and fully welded in, total total c**t to do, seats needed to be exactly right as i only have a couple mm clearance to the cage and tunnel, not the easiest to access to weld either, so im chuffed these are done.
Picked up some 4 pin hitachi coilpacks so when I come to make up the loom I can delete the ignition amplifier which tends to be the weak point of the AGU ignition system.
Before when the car was running FWD i was using a BAM inlet manifold and fuel rail with brand new EV14 bosch 550cc injectors, with the car being RWD now i need to use the AGU inlet manifold which isn't suitable for EV14 injectors, luckily creation motorsports make these little injector spacers and adapters so that I can run my Bosch 550s on the AGU big port mani. Looks like there shouldn't be any issues but will have to wait and see.
So now running 4 bar FPR, 550cc injectors and tig welded rail for AN fittings, should be plenty for fuelling everything the KO4-064 demands!
Turbo oil feed line from a longitudinal 1.8T is a good fit, and I've started to tack together a downpipe, going to try and make the exhaust myself, 3" from turbo all the way back.
Its going to be tight as hell but its do-able for sure.
Will run alongside the gearbox then dip under the propshaft all the way to the back of the car.
Theres currently a b6 1.8t solid mass flywheel on the engine, in order to get the thing started up initially and check i have drive to the rear wheels i will use a b6 1.8t pressure plate and an old ford pinto friction disc as the rx8 input shaft is identical to that of the pinto/type 9 gearbox input shaft, the b6 1.8t stuff is only 228mm so what i have done is bought an audi 80 solid flywheel, these can be machined out to take a 240mm setup. I've been in touch with CG motorsports to have a custom clutch kit made up to handle all the power and torque i can throw at it, but this will come later on. Just want to hear it running and check i have drive for now.
Been making up some little temporary wishbone extension plates to sort out the front camber situation, this is only to determine how much wishbone extension is required, i wont be running these plates all the time.
I still need to cut the arches on the wings too as they rub as it is
Cut up my sump in order to modify it for my engine being vertically mounted, got rid of the oil level sensor hole too.
Made up this plate from 3mm alloy plate and will have an M14 bung welded in too for the drain plug. Will keep the original drain plug there too and just run two magnetic plugs. twice as more likely to pick up any shit in the oil that way!
Also have a spare rocker cover from a B6 1.8t, these do not have the breather on the end so i have drilled and relocated the breather to suit my needs and make things more accessible, will have this AN-12 fitting welded on for the catch can piping.
Lastly the oil pickup pipe will also be welded to accommodate for the vertically mounted engine, similar to the sump, it is currently 15 degrees out.
My TIG skills are not quite there yet so I think I'll have someone else do this!
Finally, rolled it outside to blow some dust off it and to get a pic alongside the daily hack
Two mk2 scirocco AGU 1.8Ts, but at the same time two very different cars! haha
Heres a link to the latest video
https://youtu.be/m6OZy3h2L9Q
Any subs/likes etc appreciated
Thanks for reading :)
mk2daz
Re: Mk2 RWD 1.8T
Post by mk2daz »
Quick update on state of play...
This is probably the most its ever looked liked a car again! front end fitted up and seats etc all in, starting to take shape.
Been focusing on the engine bay side of things, modified sump and pickup pipe are now done and on the car running two magnetic drain plugs for the sump, B6 A4 rocker cover has AN-12 take off for catch can system, massive pro-ram cone filter plumbed up with 90mm -> 60mm pipework with DV relocating into the FMIC pipework, running an ARF baffled catch can mounted to the inner wing, starting to come together nicely!
16 row AN10 Mocal oil cooler mounted up front
Mocal oil cooler thermostat sandwich plate and mocal relocation plate with a 1/8 NPT take off for oil temp gauge (got my pressure gauge hooked up for now for first start up) for remote oil filter
Allows me to run this beast of an oil filter, T4 2.5 diesel van, massive!! Also very very easy to access for future oil changes.
Pipework for the oil system, all AN10 push on style fittings with oil rated hose
This brings the total oil capacity to just over 6L give or take, despite having to remove a bit from the sump, very happy with that!
Downpipe version 2 tacked together, this is going to need to change slightly again, more on that in the next update!
It basically needs to run tighter to the gearbox especially at the bellhousing section to make for some more space around the pedalbox area.
Now, sussing out the flywheel, starter, clutch, spigot bearing etc!
After notching the bellhousing a bit to allow the starter to fit i have the following combo:
Audi A4 B5 1.8t flywheel, starter and pressure plate
2.0 Ford Pinto clutch disc (just for testing!)
Rx8 slave cylinder, clutch arm, release bearing etc
I've plumbed and bled the clutch and it looks like this setup will work after a small bit of tweaking to allow for a little bit more play in the clutch fork. Obviously I will go for uprated components for the final build to handle the torque of the 20vT, this is just for proof of concept!
Ford Type 9 spigot bearing fits a treat as the VW crank is 21mm bore and the rx8 input shaft 15mm, exact same as the ford dimensions!
Gearbox mount version 4! This one is nice and compact and uses some old mk2 escort anti tramp bar bush ends welded to an offcut from the seat rails, i've pressed in new tramp bar polybushes. This is then welded to an 8mm plate i fabbed up to bolt to the back of the rx8 box.
this all then bolts in to 2 'bolt on' brackets that bolt to the inside of the tunnel via plates with captive nuts that i've made up and welded to the inside.
Nice and strong and makes removing the box much easier now! and i can fit a 3" exhaust under the mount too.
Right, time to chuck some wiring in, hook up some fuel lines, set up a very rough base map on the emerald and see if she will start up!
First of all, my butchered ce1 1.8T engine loom i made up previously had been cut up a bit for some bits on my other car so this needed rectified first.
Mainly adding new plugs for starter, new TFSI n75 wiring, injector wiring, map sensor, and eventually the 4 pin coils (although im going to start it up on the 3 pin coils first)
Reverse lights working with the RX8 box!
Fuel lines are exactly as they were before (now far too long!) and fuel system also as it was, facet lift pump feeding swirl pot, inline filter then bosch 044 pump up to the rail.
Of course, this is all temporary just for starting it up, proper brackets, fuel cell etc will be used!
Quickly calibrated a rough map on the Emerald ECU and after robbing a couple relays from my daily car I was ready for the first fire up.
CRanked it for about 15 seconds and nothing, pumps had primed but im presuming had only filled the swirl pot.
Next crank she fired a bit...
Next crank she fired right into life on all 4's and idled away lovely!! Get in.
Oil pressure reading nice and high on the gauge, lambda readings a bit high but then again my downpipe is only tacked together, also no gasket or anything.
put it up on the lift and tried a few gears while operating the clutch pedal by hand, 1st good, 2nd good, 3rd good!! rear wheels were going like mad so didn't go any more than that.
Beyond chuffed with it, she is now officially Rear wheel drive!
Here are the latest youtube videos that go a little more in depth on what I've done.
Oil system and engine bay
https://www.youtube.com/watch?v=ToAt7OGWfbw
Clutch, flywheel, spigot bearing, starter, etc etc
https://www.youtube.com/watch?v=PN4dGS6xkpM&t=7s
The first start up video will be coming out this weekend hopefully!
Thanks for reading. Daz
mk2daz
Re: Mk2 RWD 1.8T
Post by mk2daz »
Here is the latest YT video for the first start up and also running it up on the lift in gear!
https://www.youtube.com/watch?v=SVheRko9Giw
mk2daz
Re: Mk2 RWD 1.8T
Post by mk2daz »
Finally got my bulkhead and tunnel all tacked up with the engine and box still bolted up to ensure everything clears.
Complete pain to do, especially round the drivers side as the pedalbox, steering column and 3" downpipe are all fighting for the same space.
Can now drop the engine and box out and get everything fully welded up before doing a bit of surgery to the dashboard to get it to fit!
Original scirocco steering column modified a bit to suit my driving position better
Made a bit of a start to the exhaust too, 3" all the way back from the turbo, should be relatively straight forward from here onwards!
And after a couple discussions with Richard at North East Brakes I have a plan in place for my front brakes, will be using Renault Megane 225 4 pot brembos with a focus ST170 front disc, so all those bits and bobs are with him now to have some caliper carriers machined up.
Full steam ahead now, I want to be driving this thing this year!
mk2daz
Re: Mk2 RWD 1.8T
Post by mk2daz »
Engine and box out earlier this evening, spilt gearbox oil everywhere..woops
Engine bay is massive now!
Made a start to the welding on the engine bay side, so far so good
some decent penetration
below view
essextom
Re: Mk2 RWD 1.8T
Post by essextom »
what tube did you use for your cage and what did you bend it with?
mk2daz
Re: Mk2 RWD 1.8T
Post by mk2daz »
essextom wrote: Wed Jan 12, 2022 8:36 am what tube did you use for your cage and what did you bend it with?
Hey Tom, its 2" cds Ropt510 rollcage tubing, I never made the cage myself but i'm sure it was all bent on a hydraulic tube bender.
hope that helps
Daz
essextom
Re: Mk2 RWD 1.8T
Post by essextom »
cheers mate
mk2daz
Re: Mk2 RWD 1.8T
Post by mk2daz »
Tunnel and bulkhead now fully welded up inside and out
Engine has been in and out a couple times to check everything clears, which thankfully after loads of welding, it all still clears and fits.
Downpipe is now on version 4(!) where it has been split into 2 sections with a V-Band to make for easier removal/fitting.
Very happy with how it has all turned out, just need to go back in and buzz back / tidy up some of the welds before i can nail it all in some epoxy primer.
While the engine is still in though I'm going to build up the remainder of my exhaust so i can weld hangers/brackets etc to the inside of the tunnel.
Going to be doing a bit of surgery to this dashboard next to get it to fit around the cage and around the bulkhead!
C 20 CCO
Re: Mk2 RWD 1.8T
Post by C 20 CCO »
Loved checking in on your fascinating build Daz, thank you for keeping us updated. 👍🏻.
kind regards,
Dave.
To be old and wise......
mk2daz
Re: Mk2 RWD 1.8T
Post by mk2daz »
Dashboard is now in, started mocking up switch panels and stuff too
Cheap nylon gearknob off ebay and a new CV boot i found in the boot of a BMW E39 in the scrappy, grabbed it thinking it could work as a gearstick gaitor, fits like a glove around a mk2 escort bolt on alloy plate thing!
welded up the rear washer jet hole
Got rest of my exhaust tacked up, 3 inch all the way from turbo back, with a backbox/silencer, side exit to drivers side, hanging off two E36 polybush gearbox mounts, mounted in the X and Y planes to keep full system stable, all clears the propshaft nicely
Have strengthened and notched the sill for the tailpipe to exit through, just need to clean back the welds a bit more
Next up is the boot floor, too complicated to make up in one piece so made it out of individual sections, fits nice and tight to the box section frame so will weld underneath too once car is on the spit
rear axle setup on and off multiple times to check clearance etc during fabrication
Front brakes are now finished and mounted up, quick spec
- Renault Megane 225 4 pot brembos
- 300mm focus st170 disc (could have went bigger disc but i may run 16s in future, 300mm is plenty)
- custom carriers and spigot rings machined by Richard @ North East Brakes
- hub is cut from porsche 924 front disc, pressed in some 14.3 spline studs to match rears
Very happy with the setup and now the brakes are fully sorted other than running lines etc!
"drift lock" ...
Last peice of fab work before i strip it down for the spit is extending the front turrets, main reasons i want to do this is to extend the damper travel and to open up more options for different top mounts, with the extra track width as well my struts sit at more of an angle, so the extended turrets can compensate for this to ensure the spherical bearing in the top mount has an easier life.
Made up some rough cardboard templates, and ordered up some 2mm plate
Need to offer up the bonnet to check how much i can extend them by, I've got two bonnets here and they are both pretty knackared, just got to work with what i've got. Im happy to cut away some of the underside of the bonnet if need be as it weighs a tonne, plenty of engine clearance to the bonnet too for a strut brace, more on that later!
Anyway... Here she stands
Also...
Fresh 12 month ticket for the daily too, failed on a bottom ball joint but a quick lunchbreak fix and it was through, happy days!
treefingers
Re: Mk2 RWD 1.8T
Post by treefingers »
Rear floor in.. good progress mate! not too far off paint now!!
mk2daz
Re: Mk2 RWD 1.8T
Post by mk2daz »
https://www.youtube.com/watch?v=9AU1UHduqnI&t=20s
More of me talking crap in the latest YT update!
