Don't know German? look here
Evening all. Just discovered some of my hoses are kaput, and having a nightmare trying to find this one to buy, as I can't seem to find it in any of the part catalogue diagrams.
Yeah that's what the hoses looked like when I bought it around a month ago.
I'm trying to sort out the engine at the moment as it was running really rough / misfiring, so all the vacuum hoses are currently off, but it's good to know they need sorting out. Here is the same photo without the black overlay....if there are any other weird issues you spot let me know. It's my first Scirocco so it's tricky for me to spot anything odd!
yellow hose is part of vac advance, its on 3 of my mk1 cabbies mark1gls. little switch is mounted on air/cis meterhead. also seen it connect to the nr valve above rocker , along with the MFA meter hose.
